Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Fuel systems Q&A
Fuel systems Q&A Carbs, injection, tanks, lines, pumps, everything fuel system related!
Old 11-23-2019, 09:12 PM
Bruce R's Avatar
Bruce R Bruce R is offline
Default Injection question
My old 88 s-10 had a throttle body injection and hei with the separate coil. Would it be possible to cobble this onto an old Buick v-6 ? What all would I need to strip off the s-10 ?
Old 11-23-2019, 10:01 PM
Bamamav's Avatar
Bamamav Bamamav is offline
The distributor controls the injectors along with the computer. You would probaby need to find a Buick v6 that has fi to rob the parts off of.
I'd keep it simple, hei and carb.
Old 11-23-2019, 11:27 PM
Two entirely different engines. '88 S10 had a 2.8 60° V6. Buick V6 is a 90° design. Nothing interchanges as far as I know...
Old 11-24-2019, 09:29 AM
Old Iron Old Iron is online now
How old of a Buick V6 are we talking
Old 11-24-2019, 07:41 PM
I don't think it matters, OI. All Buick V6 engines are 90°...
Old 11-24-2019, 09:43 PM
Bamamav's Avatar
Didn’t some later big Buick’s use the V6 in a fwd configuration, and called it a 3800? Or is that a totally different engine?
If it’s the same block as the older ones, you could probably swap all the stuff off of a 3800 with the computer and wiring out of the car.
I had a few of the old style even fire engines, tough as nails. I put one with a Saginaw 4 speed in a Toyota pickup. With the factory 4.11 gears, it would pull like a v8! Oh, it had Hei from the factory, but had a two barrel carb.
Old 11-24-2019, 11:38 PM
Bama, he's talking V6 Chevy components to V6 Buick. Nothing from the 60° 2.8 V6 or the later 90° 4.3 V6 interchanges with the 90° Buick to my understanding.
There were some RWD Buicks that used the 60° bellhousing pattern... so you could, theoretically, put a 3.8 Buick were a 2.8 Chevy once resided.
That's what I think I know. No wagers, no guarantees...
Old 11-25-2019, 09:46 AM
Thanks Doc, I didn't know they were different. They must be wider from vale cover to valve cover then?
Old 11-25-2019, 07:21 PM
There were several iterations, derivatives, displacements and deck heights in the V6 Buick's 47 year history. I count 13 versions, so visually and dimensionally, all over the map.
Bama, I misread your last post. Sorry, you're right... you'd need the FI and ignition from the same series Buick, or possibly aftermarket...
Old 11-25-2019, 11:08 PM
Bamamav's Avatar
Right Dr C. Chevy and Buick stuff entirely different.
