Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Frame/Suspension/Brake... Talk & Q&A
Old 11-05-2019, 02:38 PM
Az33 Az33 is offline
Default Bolting Heims to frame
How are you guys doing it?
When bolting a Heim joint or other rod ends to the frame are you welding a nut to/in the frame to screw in to? I donít have a whole lot of room between the frame and outer edge of front axle so canít really do a bracket. Going to be a 4 bar set up.
Pics please if you have them.
Thanks
File Type: jpg 4EC0E634-E52B-4E33-9D33-47913697719A.jpg (107.0 KB, 47 views)
Old 11-05-2019, 03:10 PM
lowbudget50's Avatar
I drill all the way through the frame. Then slug the frame with a tube so the frame doesnt collapse. Then bolt all the way through it.
I'll post pics later. Dont have any on me
Minterfab.com
Old 11-05-2019, 03:48 PM
I use a threaded version of these!
https://www.speedwaymotors.com/Frame...ir,215975.html
Old 11-05-2019, 04:14 PM
I do the same as LB
DOM tubing
I don't use any other bolts/fasteners on my builds other than grade 8 either.
Old 11-05-2019, 05:24 PM
05snopro440's Avatar
Those are neat!
My '46 GMC on Photobucket
Old 11-06-2019, 12:16 AM
MercuryMac's Avatar
Builder Junky!
I've only put heim joints in lighter strain situations and I've welded the big nut in the frame.
Old 11-06-2019, 06:22 AM
BillM's Avatar
BillM BillM is offline
Same as LB, I put a tube completely through the frame. I used heims at the axle and then a urethane bushed joint at the frame end - I'd read it absorbs a bit more and lessen's the shock transferred to the frame.
Old 11-06-2019, 07:51 PM
smallfoot's Avatar
I used the radius rod bracket to the frame and bolted the rods to the bracket...40,000 miles ago...
Old 11-08-2019, 08:24 AM
Sounds good, thanks guys. Think I will go ahead and slug it and bolt through the frame.
