Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Tech Tips!
Old 11-25-2019, 04:48 PM
70Newport 70Newport is offline
Default Finally back building!
After being a golf pro all summer and my son being born October 15th I am finally back at building my 47 ford. I have suspension well on its way and motor mounts mocked up. Now I am trying to figure out steering on the cheap.
Aside from vega boxes does anyone have a recommendation for a box and steering column that are easy to come by for cheap? I'm hoping for power steering so my wife will drive it too otherwise I would probably go with a cowel setup.
Thanks in advance,
Gary
Old 11-25-2019, 05:44 PM
05snopro440's Avatar
Thanks in advance,
Gary
What style of build are you doing, straight axle front, ifs, fenderless?
My '46 GMC on Photobucket
Old 11-25-2019, 08:03 PM
F1 box and column from the original truck, or one like it. Power steering is a different animal, but you really shouldn't need it on a lightweight hot rod.
Cowl steering is (generally speaking) a bad idea due to poor geometry.
You might get better results if you post the question in your build thread...
Old 11-25-2019, 11:31 PM
Bamamav's Avatar
Bamamav Bamamav is offline
I used a power box off a S10 pickup with some kind of Chevy column in my 47 Lincoln. I think they sell a bracket for a Ford that bolts it right in, I had to fab my own mounting as the Lincoln is a little different.
I havenít driven it yet, but sitting in the carport it steered easily with two fingers.
Old 11-26-2019, 03:40 PM
Yes it is a straight axle, and fenderless. Costom frame, 47 ford 1 ton cab. transverse leaf front suspension.
Old 11-26-2019, 03:43 PM
Thanks Crankenstein, I will add this in to my build thread as well.
I have what I think is a factory manual box but it doesnt seem to want to turn at all. I looked at having it rebuilt but the cheapest I can find to get that done up here in Canada is $489 plus shipping there and back so I will be around $600 plus figure out steering column etc. Seems steep to me.
Old 11-26-2019, 07:33 PM
Odies dad Odies dad is offline
I have a unisteer rack and pinion in my model A and even without power steering, it steers with one finger. Bolts to the Vega box mount.
