Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Transmission, Rear End... Talk & Q&A!
Old 10-26-2019, 02:14 PM
Bonehead's brother's Avatar
Bonehead's brother Bonehead's brother is offline
Default 700R4 overdrive tranny question
Do I need to put in a toggle switch to lock the Torque Converter at highway speeds? Or will it work ok without it? If it needs a switch, is there an easy way to install it? I like easy.
Yes I have welded in flip-flops, I live in Florida.
Old 10-26-2019, 02:17 PM
Mine all have a single hot wire to the tranny... no computer! My tranny guy uses some sort of switch that plugs into the tranny case... I'll ask what it is! You definitely don't want to go with a toggle... that will drive you insane!
Old 10-26-2019, 02:34 PM
skull's Avatar
skull skull is offline
there is a vacuum switch and a switch off the brake pedal external set up, l used this on the 1948 dodge truck and it works very well.
on the 3Oish it has an internal set up my tranny guy put in so no nothing to hook, just plug and play.
link on google for many styles, talk to local tranny shop and many can do it for a reasonable fee.
MAKE SURE THE TV CABLE IS ADJUSTED PR0PERLY 0R IT CAN BURN UP THE TRANS QUICK
this is the kit l used on the 48;
https://www.summitracing.com/parts/prf-60109/
https://www.google.com/search?<br />...hrome&ie=UTF-8
Later
my opinion only, valid where prohibited, for official abuse only.
1928 maxwell hybrid build/drag car
http://ratrodsrule.com/forum/showthread.php?t=37455
1948 dodge truck in deceased son's memory.
http://www.ratrodsrule.com/forum/sho...odge+truck+son
1930 2dr mopar.
http://ratrodsrule.com/forum/showthr...ht=30+mopar+dr
Old 10-26-2019, 02:38 PM
sneakysnake's Avatar
sneakysnake sneakysnake is offline
"There’s nothing new in originality"
Following
'46 Build Link
'53 Build Link
"Its a catastrophic success"
Old 10-26-2019, 02:42 PM
Default TV Cable adjustment
https://www.google.com/search?q=700r...hrome&ie=UTF-8
Later
This worries me. I have looked at some vids on this. Most just say to get it snug and adjust it as you drive it, warning me not to leave it too loose to begin with. How do most people set it up to start with?
Old 10-26-2019, 02:57 PM
skull's Avatar
Default stuff
https://www.thirdgen.org/forums/tran...djustment.html
http://www.tvmadeez.com/article/index.php
http://www.v8s10.org/forum/viewtopic.php?f=19&t=39331
Later
1930 2dr mopar.
Old 10-26-2019, 03:59 PM
If the tv bracket is pretty sturdy then all ya have to do is push the cable adjuster to let the cable extent then push the pedal to the floor. It'll automatically pull the cable to real close to the adjustment it needs.
I run a key on hot wire to the plug on the tranny and don't worry about disengagement. It'll do that when it downshifts to third or you slow down below the 4th gear shift point.
Old 10-26-2019, 09:14 PM
I have always just made mine tight like my throttle cable. You can adjust it a lil for harder or softer shifts... just don't make it loose! Taking off once & letting it shift will tell you if you're good! At least that's how I adjust them & drove my Chevelle like that for 10 years & my Nova for 16... no prob!
Old 11-30-2019, 12:59 PM
lowbudget50's Avatar
I use a toggle switch. Not a pain at all. Just font forget to turn it off hahahaha.
I live my 700r in my chevy. Made it a totally different truck!
Minterfab.com
