Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Frame/Suspension/Brake... Talk & Q&A
Old 07-20-2020, 08:08 AM
Lowtech Lowtech is offline
Default 2 piston master cylinder from Chevy PU
On ebay you can find a brake - clutch bracket to use an early 60 Chevy PU 2 cylinder common reservoir master cylinder as brakes and hydraulic clutch.
Anyone used this setup? Not common, so I'm thinking it might be marginal for brakes? It is a neat compact way to do it in a T bucket
LowTech
Old 07-20-2020, 12:36 PM
Dr Crankenstein Dr Crankenstein is online now
If you're talking about this thing, it's been popular for ages. I have no idea how effective it is for brakes...
Old 07-20-2020, 05:07 PM
I used one in a '34 International Pick up Had drum brakes all around and a 250 Chevy six with a Saginaw 4 speed. Still on the road since 2008 with the same set up.
Old 07-21-2020, 08:21 AM
They used them on the 1960 Chevy pickup and they actually worked quite well.
Dodge also use the same type of master cylinder on their pickups in the 60's
Old 07-21-2020, 09:06 AM
International used them also. The Chevy units have the brake cylinder to the outside and the clutch to the inside. You must move the check valve in order to use the inside cylinder for the brakes. International master cylinders are set up right for hot rod use but they are hard to find. Rock Auto has the Chevy units.
Old 07-21-2020, 09:14 AM
Blue Eyed Devil's Avatar
Devil's Advocate
This.
Grind the "brake" and "clutch" castings off if you're easily confused, or leave them to confuse onlookers.
Also, they work great. As far as the bracketry, I can't speak to the eBay item. However I have used the Tardel swing-pedal setup it is copied from, and it worked out very well in a tight space.
Old 07-22-2020, 05:55 AM
That's it. Thanks everyone for the inputs
Old 07-22-2020, 07:33 AM
Bamamav's Avatar
Bamamav Bamamav is offline
I drove an old 61 or 62 Chevy pickup with that setup for a while, worked good with the drum brakes on it, would lock up the wheels if you needed to.
