Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Frame/Suspension/Brake... Talk & Q&A
Old 03-20-2020, 06:23 PM
senginc senginc is offline
Default Mustang II with or without sway bar
I know plenty of you have experience with a Mustang II front suspension and would like your opinion.
I have installed maybe 5 or 6 in the 1990's, but I don't remember ever having a front sway bar.
Seems like on those cars, maybe because they were stiffly sprung, they didn't seem to need a front sway bar ??
So on this project I am considering Mustang II with or without sway bar now that sway bar kits are plentiful.
Any thoughts, my weight distribution will probably be about 55/45 and 2500 lbs.
Old 03-20-2020, 11:09 PM
I love MII front ends & have always run a sway bar on them... I figured why not!?
Old 03-20-2020, 11:11 PM
Most definitely a sway bar
Old 03-21-2020, 06:22 AM
BillM's Avatar
BillM BillM is offline
I'd highly recommend it as well. Initially I build my uncles 29 Tudor without, and it didn't take long to install one after it got on the road - and what a HUGE difference it made.
Old 03-21-2020, 07:49 AM
I took it OFF our Mustang project because it rubbed on the oil pan. (Wrong pan) I can't say it made a big difference.
We don't have one for the coupe project either. I don't think we'll put one on, unless it drives poorly.
Old 03-21-2020, 08:39 AM
Here's what I've found out.
If the vehicle has dropped spindles the need for a sway bar is less if it doesn't, the need gets greater.
The reason is, it lowers the roll center when using dropped spindles and also lowering the vehicle.
Old 03-21-2020, 09:26 AM
That makes good sense.
Old 03-21-2020, 01:02 PM
I have 2" drop spindles, the tire size I plan to use sets the low point of my frame a little less than 5", so my center of gravity is lower than an everyday car.
Since I have coilovers I make crank it a little lower.
Old 03-21-2020, 08:22 PM
soltz's Avatar
soltz soltz is offline
The Rat Captain
Talking
I had the Pinto version on the Willys project with out, don't think it was part of the Pinto package? Handled fine to 120 mph when it started to float
Be Safe
and
Be Creative
