Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Interior Q&A, photos etc!
Interior Q&A, photos etc! Stuff for the interior! Seats, dashes, flooring, door panels... you name it!!!
Old 09-30-2020, 06:22 PM
Bamamav's Avatar
Bamamav Bamamav is offline
Default How would you fix this?
This wheel came off my parts car, I want to restore and use on my Firebird. I plan on buying a leather Wheelskin lace on cover to cover the rim after I trim back the padded area on the spokes. But, there is this hunk missing out of the rim. This is a sponge rubber type rim, real soft, so I want to fill that area with something before I put the leather on. Any ideas what might work? I want it to stay about the same softness, so any bondo or epoxy is out.
Old 09-30-2020, 08:36 PM
Cut a chunk off another wheel and glue it in.
Old 10-01-2020, 10:07 AM
Bamamav's Avatar
I wish I had another one to cut a piece off of. Guess I might be able to use a piece off of one of the spokes since it's the same softness.
Old 10-01-2020, 03:50 PM
Find a donor, Bama.
I have two GMs in service right now with "soft" rimmed steering wheels. One is a '96 pickup, the other is a 2000 cargo van. There are several others you could chop a piece out of, I'm sure...
Old 10-01-2020, 03:58 PM
DozerII's Avatar
DozerII DozerII is offline
What about using a piece of that copper water pipe insulation it is a really dense closed cell foam like that and comes in 1/2 & 3/4 inch ID. The only thing is it might not be available in the South
Glen
Old 10-01-2020, 04:06 PM
There's an idea... or maybe some roll bar padding.
https://www.speedwaymotors.com/Speed...-Inch,896.html
Old 10-01-2020, 06:19 PM
Bamamav's Avatar
That foam insulation idea sounds good, i think I have a extra piece around here somewhere. It gets cold enough to freeze uncovered water lines, so we use that stuff, too.
